Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 02-24-2008, 05:33 AM
Aand55 is on a distinguished road
I Need Help Buying the Best End Mill for hogging "304" as quickly as possible
For anyone out there with carbide experience, I work for a company who is always hogging off large amounts of 304 Stainless. I want to go to my boss about getting the best carbide End Mill (with the best coating), that would remove the most material in SFM. I also need one that would last (Or have a long life under the hard use). Can anyone help me out with this matter, and maybe steer me in the right direction. Your help is Appreciated.
Sincerely,
Overworked Machinist
Old 02-24-2008, 05:49 AM
northstarr is on a distinguished road
Lightbulb
We have had some very impressive results using "Z Carb" Solid Carbide End Mills by SGS. I am not a sales associate of SGS, just an end user. for more info see
http://www.sgstool.com/products/zcarb/testimonials.htm
Good luck!
Old 02-24-2008, 01:28 PM
Thumbs up Thanks for the info
Thanks for the info and the link for the Z Carb end mills..I'm going to check it out now......
Old 07-15-2009, 10:26 PM
ryanschmidt224 is on a distinguished road
best endmill
Its been a while since this was posted but we have been using mitsubishi feed mills and they have been incredible. They just do roughing so you need to do finish but they are worth every penny. we have saved probably thousands of dollars using these
Old 07-16-2009, 06:01 PM
Verfur is on a distinguished road
Hanita varimill
Old 07-22-2009, 08:00 AM
PixMan is on a distinguished road
What you choose depends entirely upon what kind of operations you are doing with the end mills, and what type of machine you have. Are you doing face milling, side milling, slot milling, end milling, or ???
High-feed mills are great for high material removal rates, but you need a fast-processor machine to take advantage of them. I do a lot of this, and with the Valenite V556, I also can use it to mill out bores using helical paths. If the application is big side milling, a "corn cob" style cutter can be effective.
Just what is your type of material removal task and what machine(s) are you tooling?
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Help me understand buying "used" one cnc software. l u k e OneCNC 5 11-21-2007 08:10 PM
Sieg super x3 "im buying it" Bugpac Benchtop Machines 2 01-19-2007 10:04 AM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
