Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 02-06-2008, 02:41 PM
gmilosevic's Avatar
gmilosevic is on a distinguished road
Oil Grooves
I would greatly apreciate if someon out there can help me with progamming some oil grooves on the I.d. and face of a steel bushing. The grooves are mirrored one is left hand and the other is right hand and the face groove starts in the same place one of the i.d grooves starts. I have 3 different makes of CNC lathes Mazak Quick turn with 640T nexus control, Mori Seiki SL250 with Fanuc MSC518TC controls and Deawoo Puma with Fanuc 21I-TB controls. If anyone Knows anything that can help me I would greatly apreciate it. Attachment in PDF format Please Help.
Old 02-17-2008, 12:31 AM
cncswiss1's Avatar
cncswiss1 is on a distinguished road
are you planning on using g32?
Old 02-19-2008, 07:00 AM
gmilosevic's Avatar
Oil Grooves
I intend to try using the threading cycle. But what I am not sure of is how I'm going to do the mirrored groove at 180 degrees.
Old 02-19-2008, 08:51 AM
cncswiss1's Avatar
simple solution for the second pass, reverse the spindle, do the same pass, start exactly 1/2 lead further away from the part than on the first pass . most of the time double lead threads are done that way (some mahcines allow phasing in threading and the start point need not be altered)
Old 02-24-2008, 06:03 AM
northstarr is on a distinguished road
Your Mazak will allow "phasing" of a thread cycle. In the THD process
it asks how many entry's, under MULTI for a 180° rotation that obviously would be 2.
Whats the best way to get these grooves.. kprice1658 Rhino 3D 15 08-17-2007 04:26 AM
Grooves MCX jorgehrr Mastercam 2 04-18-2007 04:58 PM
How do you cut wide grooves with a small bit? randyf1965 DIY-CNC Router Table Machines 0 04-26-2006 09:09 PM
Machining grooves itsme General Metalwork Discussion 8 10-03-2005 02:07 PM
I'm looking at getting CADCAM but am unsure if its possible to make grooves like..... Darc General CAM Discussion 1 11-12-2004 11:28 AM
