Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Want To Buy...Need help!
Want To Buy...Need help! Post items that you are looking for so people can help you to find where to buy them.
Old 01-11-2008, 07:50 PM
johnnylisa is on a distinguished road
Surplus rail slide and block
Hello,
I would like to construct a lift mechanism for a table mounted woodworking router. I think mounting the router in a frame attached to a rail slide with one or two blocks would serve to keep everything straight and true when raising or lowering the router. I would like to find a rail about 10" long X 1" wide with blocks strong enough to hold the router and frame.
This is a one time experiment (not sure if it will work or not), and used/surplus gear will probably be fine. If anyone has any suggestions for a source or input on how to put such a thing together inexpensively, I'd sure appreciate the help.
John
Old 01-30-2008, 11:13 AM
GTEN-USA's Avatar
GTEN-USA is on a distinguished road
I have a sample of a 35 size linear rail that was made in China. The balls fell out of the bearing block because someone took the bearing off of the rail but it will still work once you put it back together. If you pay the freight, I'll give it to you for free.
Slide rail for the Table prerunner68 CNC Plasma and Waterjet Machines 1 06-23-2007 10:50 PM
Linear rail and block calculation pequignotm Mechanical Calculations/Engineering Design 1 05-20-2007 05:13 PM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 01:52 AM
slide/ rail question 2muchstuff DIY-CNC Router Table Machines 13 04-14-2005 06:25 PM
PSU 25V 30A on surplus Konstantin General Electronics Discussion 6 08-31-2004 05:14 PM
