Results 1 to 3 of 3
Thread: CNC Tool Cooling
    *Registered User*
    May 2009
    CNC Tool Cooling
    Looking for a tool cooling system for my new CNC. Never used one and have no idea what is available out there. Something simple to inject liquid when cutting aluminum
    Aug 2007
    Sweden
    I don't know anything about it but i belive you need to state what machine you are using if someone is going to recommend "coolant through tool"-parts that compatible.
    *Registered User*
    May 2009
    A good idea, thank you
    It will be approx. 36"x 24" cutting area, Z travel 6", 1/2" aluminum plate construction, linear bearings & ball screws all axes, 4 stepper motors, Hitachi X200 3HP with Chinese Spindle ER20.
    Don't need very much coolant to cut aluminum but depends what is available. If cooling systems are expensive I will do it manually as needed
  1. Spindle cooling with PC Liquid cooling system
    By enforcer in forum DIY CNC Router Table Machines
    Last Post: 02-07-2012, 03:02 PM
  2. Replies: 1
    Last Post: 12-02-2009, 10:13 AM
  3. Air cooling is possible?
    By hartan in forum Fadal
    Last Post: 07-12-2009, 10:25 PM
  4. need help with cooling fan please
    By johnt in forum General Electronics Discussion
    Last Post: 03-11-2009, 10:12 PM
  5. Cooling
    By TMaster in forum Xylotex
    Last Post: 04-24-2006, 06:12 PM
