Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: Buying a CNC Lathe - HELP!!!
    Apr 2012
    Usa
    after hearing that haas isn't the best choice for live tooling , I was wondering what CNC lathe is great for 3 axis & possibly 4, and to work with mastercam.
    If I can get a list of best options it would be great.
    Thanks I appreciate the help.
    Feb 2009
    Mori seiki
    Mazak
    Okuma
    Doosan
    Apr 2012
    Usa
    Thank you
    Mar 2012
    options
    These brands are correct for the best players in this. If you were considering Haas, Doosan will give you the best value and they are top end turning machines. If you consider Mazak, keep in mind the control is different from any other control. For some reason it seems very tough to learn another control after learning Mazak but it will ultimately depend on the application. Whoever gave you the advice on the Haas was doing you a big favor.
    Jan 2012
    Are you looking for simple turret style turning with Y axis live tooling (lots of players) or a B axis tool changer machine (limited selection)?
    Apr 2012
    Usa
    i was considering a simple controller like haas, also i need the CNC lathe to be pretty effecicent, i know mori seiki is way outta my price range but i was seeking something more above haas prices on there lathes, so what CNC lathe is best?
    Also if i speaking correct,
    the X,Z standard.
    but for
    C=axis is something you would create like a "hex shape"
    and the
    Y=axis is where i can drill into the "material"
    ALSO "NO" im not looking for "B" axis turrent
    thank you.
    Jan 2012
    Quote Originally Posted by Bisorcam View Post
    the X,Z standard.
    but for
    and the
    thank you.
    If you want efficient turning as a main factor, I agree, no B. The four mentioned by "underthetire" are definitely the place to start & you'd probably be pleased with any of them. There are a lot of other players in that market, but none I would reccommend over these. And I'd agree that Doosan may be the best value here, dependent upon how you plan to use it. (If it's going to run a lot versus sit a lot makes a big difference).
    Yes, C-axis gives you the ability to mill/drill on the face of the part with a tool parallel to the Z axis (your hex example) using the CX axes for interp motion. Y axis gives you additional capabilities. I'd highly recommend Y-axis consideration. You'll probably quickly find it useful.
    Just my opinion,
    Dave
    Apr 2012
    Usa
    So the best choice of axis would be X,Z,C,Y?
    And for example say I have a shaft and I wanted to drill into the OD, "y" would come an perform that for me?
    Feb 2009
    If you want to drill or slot off center, yes.
    Mar 2012
    What size parts do you need to do?
    That will make a big difference in who I might consider.
    A Y axis is nice to have if it's not much more and it should not be unless you go with a Mori than be prepared to write a big check unless it is for the lower end machine. That said the machine will last until you retire.
    Mar 2012
    I take that back, I don't think Mori has a low end y axis like the Dura Turn.
    Apr 2012
    Usa
    Probably like 3 1/2 " OD max. But I just wanna have the Y in case I have parts that need drilling
  • Page 1 of 2 12 LastLast
    1. NEED HELP BUYING LATHE
      By ghd123 in forum Want To Buy...Need help!
      Last Post: 04-16-2011, 03:52 PM
    2. Is this lathe worth buying?
      By dneisler in forum General Metal Working Machines
      Last Post: 02-12-2009, 06:21 PM
    3. Buying First Lathe
      By phantomwarrior1 in forum Mini Lathe
      Last Post: 08-10-2008, 03:04 PM
    4. Help buying a lathe
      By Napier in forum Mini Lathe
      Last Post: 02-14-2007, 12:12 PM
