I'm looking for a copy of the Superior Electric Cad to Motion Program they offered for their MX2000 Motion controllers. The Superior Part Number: MX2000-CTM
The following is a description of the function of the program.
The MX2000 CAD-To-Motion software
enables the user to "draw" their motion profile using standard
CAD packages. The software then converts the CAD files, stored in a
DXF file format, into an MX2000 task file.
MX2000 CAD-To-Motion displays the drawing and copies the DXF
data into three tables named lines, polylines, and arcs/circles. When
the user selects an item in one of the tables, the item is converted into
MX2000 SEBASIC code and is shown in the task file edit window. The contents of the edit window are then saved and imported into the MX2000 programming environment as a task file.
If you have a program and would like to sell it or may know of a source for this program please contact me @ davidsedgerly@verizon.net
I have the following MX2000 components:
3- SS2000D6
6- superior electric encoded stepper motors with the following spec’s
Stepping motor
Type KML063F13C4
1.85 VDC 6.6 AMPS
200 step/rev
Connect per 213803/219273
Encoder 400 PPR
The MX2000-8 set up:
1- MX2000-8 power supply
1- DSP with 32 megs Ram
1- Digital I/O Board
4- Duel Axis interface board
1- I/O BCD Expansion board
All the details to these components can be found in the Pdf Catalog
