Results 1 to 5 of 5
Thread: need help in heidenhain itnc 530
    Mar 2012
    israel
    hello everyone!
    i'm working on a hermle c-30 heidenhain control and i would like to set datum automaticly using a program (i would like to be at a certain coordinate and "save" it in the preset table- the values of x,y,z,c,a)
    can anyone help me
    Nov 2008
    Finland
    Check the SYSREAD (ID270) and then SYSWRITE (ID 503)
    You can read the axis values and then writen them to the PRESET table.
    Fairly easy function. (you need to enter the CODE NUMBET 555343 to get the SYSWRITE functions available. Everything is in the normal user manual.
    Jukka
    Mar 2012
    israel
    thank you for answering i found that on the manual , but could you post an example on how i write it in the program i would like to be in a certain position and read and write the coordinates in a different home number how do i do it?
    Nov 2008
    Finland
    Here is an example:
    0 BEGIN PGM test MM
    1 FN 18: SYSREAD Q1 = ID270 NR1 IDX1 ; Read X-axis position
    2 FN 18: SYSREAD Q2 = ID270 NR1 IDX2 ; Read Y-axis position
    3 FN 17: SYSWRITE ID 503 NR10 IDX1 =+Q1
    4 FN 17: SYSWRITE ID 503 NR10 IDX2 =+Q2
    5 END PGM test MM
    It reads the position of the X- and Y-axes and writes them to PRESET table at line 10.
    Fairly easy, don't you think?
    Jukka
    Mar 2012
    israel
    thank you very much you helped me a lot.
    have a nice day
    1. Need Help!- Heidenhain iTNC 530
      By aslam819 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-19-2012, 02:18 AM
    2. Need Help!- Heidenhain iTNC 530 question
      By Brian Brown in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 12-19-2010, 04:53 PM
    3. Need Help!- TOS with iTNC 530 HEIDENHAIN
      By SheldonB in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-14-2009, 11:35 PM
    4. heidenhain itnc 530 - Q parameters
      By greenchair in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 09-11-2008, 02:22 AM
    5. Heidenhain iTNC 530
      By Thanya in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-12-2007, 05:33 PM
