Results 1 to 5 of 5
Thread: CNC Square tub cutter needed
    Feb 2012
    I have been looking for a programmable CNC square tube cutter for weeks with no luck.
    Preferred specs:
    Less than 120,000
    Computer programmable
    Cuts all angles
    Tubing from 1" x 1" to 4" x 4"
    Semi automatic (I can have an operator load the machine even though automated would be preferred)
    Please help. I'm getting desperate
    Jan 2006
    Are you looking for a band saw or what? Need some more specs of what you are trying to do.
    Matt
    Feb 2012
    Preferably laser or plasma. I am trying to cut down on operator time. Basically I would like to load a ten foot section of 1x1 tubing into the machine and have it come out with 9 1' sections/various miters.
    Jan 2006
    Laser for $120k, even used....You are dreaming.
    Plasma maybe but you'd have to have a rotary holder for the tubing to cut all the sides. If you just need simple miters, get an automatic cold saw. I'm sure you could get a dandy for $120k.
    Registered Diverdude's Avatar
    Feb 2012
    seen this the other day, says model 2400 cut square and rectangle tube
    CNC Plasma Rotary Tube Cutters : Pipe Cutters : Plastic Tube Cutting : Tubing Cutters : PlasmaRoute CNC, LLC.
    1. CNC cutter needed
      By wdosr in forum Want To Buy...Need help!
      Last Post: 04-19-2011, 11:47 AM
    2. Woodcarving cutter advise needed
      By FriendOfGhost in forum WoodWorking
      Last Post: 04-14-2010, 04:02 AM
    3. Square D starter/contacter help needed
      By mt92 in forum General Electronics Discussion
      Last Post: 12-04-2007, 10:10 AM
    4. Thread Mill Cutter Help Needed
      By TZ250 in forum General Metalwork Discussion
      Last Post: 10-05-2006, 01:40 AM
