I see them in the Boston Gear catalogue, also you need to specify whether 20° or 14.5° pressure angle.
You may have to bore out to 1/4"
They have a few local reps in Canada.
Hi guys I spent hours looking on the net trying to find a 20 dp pinion gear 12 teeth with 1/4 bore and 3/8-1/2 face. Anyone know a good source I can buy on line?
Dan
Hi I'm looking for 20° Pressure Angle sorry forgot to add that
Here is all the Boston Gear dist in Ontario!
Search for Other Distributors
sounds like a resolver feedback gear; sterling has good interactive site to enter the info and it pops out proper gear with p&d:
Precision Mechanical Components Timing Belts Pulleys Spur Gears Couplings Bearings Sprockets Retaining Rings Brakes Helical Gears Clutches Universal Joints
we work with Evelyn: edeoliviera --at--sdp-si.com
(516) 328-3300
Mike (at) KilroyWasHere (dot) com -- servo/spindle/vfd motors/drives/controls sales/service/repair/retrofit
If you don't find what you want we are a custom gear house and we do a lot of short runs & prototypes. Yes price would seem high for 1 gear but you may have not other alternative. I know it wouldn't be your first choice but we could be an option.
Greg Scott
American Gear, Inc.
Precision Gears for Every Industry and Application - American Gear, Inc.
