Results 1 to 2 of 2
Thread: What small CNC Lathe should we buy?
    Dec 2011
    The company I work for is considering a CNC lathe. I am the sole machinist in the shop and the company's focus is R&D. It is my opinion that a lathe with a 6in chuck capacity with a relatively hight RPM (think mostly aluminum) and live tooling is what we would need. The Haas ST-10 fits our requirements and cost. Is there any others that we might consider or is the best bang for the buck. Keep in mind that this is a R&D shop. Ease of use is more the issue than high volume.
    Registered mechematt's Avatar
    Nov 2008
    For the money and lower volume, primarily aluminum work you are talking about a small haas is a fine choice, and the redesigned ST series is almost a real machine tool (just kidding...sorta). I would only say that if you can swing a little $ look at the -20 instead. I have an SL20 and an ST-20, they are small. you will outgrow the 10 fast especially if you intend to do anything with the live tooling (not a lot of room there for clearing tools such).
  1. Replies: 15
    Last Post: 05-05-2011, 06:59 PM
  2. Which small lathe in UK?
    By martinw in forum Mini Lathe
    Last Post: 02-27-2008, 02:31 AM
  3. Small job for CNC lathe
    By Joe T. in forum Employment Opportunity
    Last Post: 02-20-2008, 11:47 PM
  4. RFQ - Small lathe job 100 qty.
    By warpedmephisto in forum Employment Opportunity
    Last Post: 08-02-2006, 04:51 PM
  5. Lathe Comparison - Best small lathe for CNC
    By acondit in forum Mini Lathe
    Last Post: 03-23-2006, 08:10 PM
