Results 1 to 2 of 2
Thread: Newbie needs engraving/routing advice
    tra
    tra is offline
    Oct 2009
    I'm a complete newbie to CNC machines. I want something to route pcbs and engrave aluminum. I was thinking a Zenbot Mini with a Proxxon IB/E to start out. I'm worried it might not be up to engraving aluminum, but then again, I have handheld engravers (cheap-o $20 ones) that work on the aluminum.
    (As a side note I also might want to cut out wood pieces for my daughter's dollhouse stuff).
    Your thoughts? I don't want to invest too much just in case I end up with a bunch of unused tools on my bench.
    Registered rich909's Avatar
    Feb 2011
    U.S.A.
    Hi --
    Quote Originally Posted by tra View Post
    The Zenbot mini is a good machine and there are many very satisfied users. It can be a good starting point or a good "occasional use" tool. If you have the budget, I think the next step up (12x16 size) gives a better range of job capabilities and allows the use of larger Bosch Colt size spindles.
    Personally, I wanted a turn-key machine that was 150lbs or under ...and affordable. I ended up with the Zenbot 1216. I've had it for nearly one year and I am still very happy.
    The mini should certainly be up to engraving aluminium if you are looking for what you get with a $20 handheld device, and the result will be MUCH better. If you want to do diamond-drag engraving it may be hard on your spindle. Take a look at: Zenbot quick start notes ...for some examples (msg# 12 & 15) of engraving I've done with my Zenbot.
    HTH.
    --Rich
  1. Replies: 0
    Last Post: 11-25-2009, 06:56 PM
  2. Need Advice: Routing Plexiglass
    By animuL in forum Glass, Plastic and Stone
    Last Post: 07-30-2009, 11:17 AM
  3. RFQ Wood Engraving / Routing (poplar)
    By danieljay in forum Employment Opportunity
    Last Post: 11-17-2007, 12:08 PM
  4. advice please- holding down extrusion for routing
    By Joa in forum DIY CNC Router Table Machines
    Last Post: 01-17-2007, 10:12 PM
  5. Need machine for routing/engraving
    By varn in forum Benchtop Machines
    Last Post: 05-30-2006, 12:35 PM
