Results 1 to 2 of 2
Thread: Ballcrews for Bridgeport
    Oct 2011
    Looking to find out what is the best route to upgrade a Bridgeport with Ballscrews. Company names, kits, etc. thanks Alexco
    Mar 2007
    Try Hiwin
    Rolled Precision Ball Screws
    i used to use the precision rolled ones all the time. The single ball nut was way better than 2 ball nuts with spring washers between them (I.E.: Rockford ball screws). If installed properly, you should have less than .001 backlash in X axis and .0015 in the Y.
  1. Retain Belt Drive or convert to Ballcrews?
    By steve_p in forum DIY CNC Router Table Machines
    Last Post: 09-21-2009, 07:25 PM
  2. bridgeport cnc
    By toolclaw in forum General Metal Working Machines
    Last Post: 12-16-2008, 11:23 PM
  3. Need Help!- bridgeport with 151
    By bbrreid in forum Bridgeport and Hardinge Mills
    Last Post: 11-03-2008, 05:35 AM
  4. Need Help!- Bridgeport Help
    By bperfetti in forum Bridgeport and Hardinge Mills
    Last Post: 10-27-2008, 09:55 AM
  5. Bridgeport TC 1G
    By Jeff Mckay in forum Bridgeport and Hardinge Mills
    Last Post: 12-18-2006, 06:37 PM
