Results 1 to 5 of 5
Thread: Can you identify this clamp??
    Aug 2011
    I need to find out more information about this clamp, but first off, I need to know what it is! Is it a clamp? Looks like clamp, but is it? The screw shown goes in freely into the top of the c bracket, and when through is supposed to screw into something else. But I'm very curious to know, what are these things called? I may or may not be a McMaster Carr item. Please help. Photos attached.
    Attached Thumbnails Attached Thumbnails Can you identify this clamp??-045.jpg   Can you identify this clamp??-044.jpg
    Jul 2008
    india
    Quote Originally Posted by caligirl626 View Post
    seems to be a puller. consider a compound shaft of a lathe or a gearbox having gears on it. it will be very handy to pull shafts having tapped holes on their ends.
    It is better to die for something than to live for nothing.
    Aug 2010
    Just a thought
    Judging by the look of the item, the welds etc it may have been a special made type of item. If you have one handy take it to a local machine shop and have them give you a bid.
    Feb 2008
    Could be a clamp or puller or a spring compressor like you might use to install shims in an OHC engine. It might be used to install pulleys or gears on a shaft too.
    Jul 2007
    It looks like a clamp used on a fixture plate. The bold is screwed into the fixture plate, the part inserted under one of the legs and the wing nut tightened. It is probably meant to hold two parts. The pivot in the middle allows it to accommodate differences in the heights of the parts.
    bob
  1. Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table
    By automizer in forum DIY CNC Router Table Machines
    Last Post: 04-27-2012, 01:46 PM
  2. toe clamp
    By ejmoreno in forum Metal Working Tooling
    Last Post: 12-16-2009, 04:10 PM
  3. Vaccumm Clamp
    By shane.vella in forum Work Fixtures and Hold-Down Solutions
    Last Post: 10-02-2008, 01:18 PM
  4. Need Help!- Building Vacuum Clamp and Mechanical Clamp Sub-Table
    By automizer in forum Work Fixtures and Hold-Down Solutions
    Last Post: 04-07-2008, 10:05 PM
  5. Vaccum clamp
    By osdhillon in forum DIY CNC Router Table Machines
    Last Post: 07-19-2006, 08:34 PM
