Results 1 to 5 of 5
Thread: Bridgeport BOSS cnc MILL no electronics. $300
    Silver Member diyengineer's Avatar
    Feb 2010
    USA-WA STATE
    Tomorrow i plan on taking a look at a bridgeport boss cnc mill Comes with no electronics, just a power supply. has a little rust, but looks to be in decent shape. The price is $300 dollars. I don't mind fixing things up and investing money, but what are the MAJOR things i should look that are technically NOT fixable? Ive already brought one machine from the grave back to life. why not another?! (the price is right, although i will have to sink a few thousand into it to get it back to life, not a problem though).
    Any info on that mill? Was it a good mill? looking to convert it over to CNC obviously.
    He has a forklift at his location, i would have to rent a forklift and probably remove the head, unless it can fit under a 7' garage door. Head probably has to come off anyways to be cleaned and painted..
    Thanks.
    Attached Thumbnails Attached Thumbnails Bridgeport BOSS cnc MILL no electronics. 0-3k43me3l95o55t25w6b7tcb63201645a31558.jpg   Bridgeport BOSS cnc MILL no electronics. 0-3nb3o63lf5v25p65r5b7t10147f4dad301005.jpg   Bridgeport BOSS cnc MILL no electronics. 0-3nb3m23o35o65z45u6b7tf3a9b704009013a5.jpg
    Sep 2004
    U.S.A.
    Looks like it has been stored outside for a while. I think I would pass on any machine that has been outdoors with that much rust; unless you plan to use it for spare parts.
    Feb 2010
    Ireland
    I have Boss series 5, I am trying to figure out the purpose of CR3, it says in operaters manuel Spindle is interlocked through CR3 with the "Auxilliary Coolant Option", what does this mean ? my problem is CR3 is energised all the time preventing me starting Spindle, if I disable CR3 then my Spindle will start ok , I have SCA board diagram, but not much help, is it somthing to do with coolant level ???
    Feb 2010
    Ireland
    boss
    Bridgport Boss 5, re CRE3 relay; CR3 is actuated by M function I beleive, my Cr3 is activated all the time preventing me running Spindle, I have a continious low on K1K, machine was running ok before being moved, should I not have a Hi here, anyone any idea????????
    Feb 2010
    USA-WA STATE
    Exclamation
    Quote Originally Posted by sean sheridan View Post
    Sean, you are in the wrong area. If you have a question (and want actualy help) locate the correct section (try metal mills). This is the "want to buy...need help" section. This thread is dead and closed.
    1. Need Help!- Boss 8 Bridgeport Mill series II Error Message
      By Stephenwinter in forum Bridgeport and Hardinge Mills
      Last Post: 03-29-2009, 11:15 PM
    2. Problem- Boss 8 Bridgeport Mill series II
      By Stephenwinter in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 03-28-2009, 11:46 AM
    3. Bridgeport Series I BOSS electronics.
      By HackerMechTech in forum Bridgeport and Hardinge Mills
      Last Post: 12-13-2008, 02:01 AM
    4. Bridgeport V2E3 CNC Mill Boss 8
      By kebell03 in forum Bridgeport and Hardinge Mills
      Last Post: 10-29-2007, 01:36 AM
    5. bridgeport mill series1 boss 4?
      By jerid1 in forum Bridgeport and Hardinge Mills
      Last Post: 07-07-2005, 07:10 PM
