Results 1 to 5 of 5
Thread: info on guide rails needed
    May 2011
    australia
    Hi everyone,
    I am looking to purchasing some parts from cncrouterparts for a diy cnc machine but have run into a hickup here in australia.
    I am looking at buying the Linear Carriage with ABEC 7 Bearings so I can do the spring loaded pinion for the cnc.
    The problem I have just come across is the guide rails for this setup, I cant seem to find any such monster in australia and to ship from fine line automation it will cost me $450 just in shipping. Is there anyone on this forum from australia who has successfully found rails for this setup?
    ikhan42
    Mar 2003
    Shelby Twp, MI....USA
    Are you talking about the aluminum extrusions, or the cold rolled steel rails?
    May 2011
    australia
    yes im referring to 1/4" cold rolled (1018) steel . This looks like its not a trach is it just a piece of steel that the rollers run on?
    Quote Originally Posted by ger21 View Post
    Mar 2003
    Yes, it's just a piece of steel. You should be able to find it locally, although it may be 6mm thick instead of 1/4".
    May 2011
    australia
    Ger21,
    Thanks for that is this a good way to go or should I get a proper rail and rollers like the dual vww tracks and the dual vee guide wheels.
    ikhan42
    1. V-groove guide bearings and rails
      By Dirtbos in forum General Waterjet
      Last Post: 11-06-2011, 08:46 PM
    2. Guide rails and weight?
      By jbro2 in forum Linear and Rotary Motion
      Last Post: 05-05-2011, 01:24 PM
    3. hiwin guide blocks and rails
      By eloid in forum Linear and Rotary Motion
      Last Post: 12-10-2007, 06:46 AM
    4. Guide Rails
      By STEVE P in forum General Material Machining Solutions
      Last Post: 11-22-2005, 05:48 PM
    5. Will this work alright for guide rails?
      By phantomcow2 in forum DIY CNC Router Table Machines
      Last Post: 11-13-2005, 05:29 PM
