Results 1 to 2 of 2
Thread: I need help chosing a laser engraver cutter
    Oct 2008
    ITALY
    Pretty simple I need the machine to cut foam inserts. An example will be the Pellican cases foam inserts.
    Material: Foam
    Min. Size to cut:
    16" x 12" approx 400mm x 300mm
    Max height of foam:
    6" approx 150mm if this is not possible the minimum required is 3" approx 75mm
    (Note has to be able to cut different thickness, in a few words adjustable height)
    My question is what wattage should the laser be?
    Machine has to be precise but due to the nature of what I will be using it, it really needs to have relative accuracy. Also a desktop model is preferred.
    As usual budget is very low. So the cheapest the best. I am a newbie so any help well be appreciated. I was looking to spend around 1000$ not including shipping. But seems quite low budget. Even a used machine will work, if spare parts and assistance are available for it.
    As for shipping I can buy in the US only if it can be shipped using USPS via Airmail, or otherwise the machine has to be delivered to Italy. That is why I was looking at China as a source. My only concern is that every time I write them I get an answer that is not related to my question. Or they just reply yes machine does it. Not making me feel very comfortable in trusting them.
    As said any help will be appreciated
    Thank you,
    Chris
    Mar 2008
    Fiji
    Although some of the Chinese lasers work quite well, support is rare and can often be a major problem. A good place to ask your question is the engravers forum at sawmillcreek.org, which is mostly for laser engravers. However, in my experience, you will have a LOT of trouble trying to cut anything that thick. The laser depth of focus is too shallow. Great for thin materials but not thick. You can cut 10mm acrylic like butter with a 45 watt laser.
  1. Need Help!- I am looking to buy a laser engraver/cutter
    By spookie91 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-15-2011, 01:43 AM
  2. New Machine Build- CNC Laser Cutter and Engraver
    By guy2b1 in forum General Electronics Discussion
    Last Post: 07-09-2011, 11:34 AM
  3. Need Help!- LASER ENGRAVER/CUTTER
    By gpenyy in forum Rockcliff Machine
    Last Post: 12-09-2010, 10:30 PM
  4. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 08-13-2007, 03:39 PM
