Results 1 to 2 of 2
Thread: Okuma Cadet Spindle Where to get one
    Jan 2010
    Usa
    I am looking for a Rebuilt Spindel for a 1997 Okuma Cadet. Cat 40 or a good place to have mine Rebuilt. Also would need taper reground.
    Gary 816/847/1100.
    Feb 2011
    U.S.A.
    Thumbs up We can Help you!!
    Machine Tool Bearings and Accessories of Elk Grove, IL can professionally rebuild your Okuma Cadet spindle.
    We are very familiar with this model spindle. We provide you with a turn-key service. From bearing replacement, "O"rings, Labrinths, Spieth lock nuts, to Belleville washers for the draw bar. We can also regrind and correct the taper. If need be, we can repair the shaft journals and/or housing by grinding, hard chrome plating, and grinding to return to original sizes. All spindles are test run-in at our facility to verify temperature and vibration.
    Give Joseph a call at (847)357-1793
  1. Problem- Okuma Cadet mate RS232
    By Colinneil in forum Okuma
    Last Post: 04-08-2012, 04:24 AM
  2. Need Help!- OKUMA CADET MATE
    By Antonio Arguijo in forum Okuma
    Last Post: 10-09-2011, 09:26 AM
  3. Okuma Cadet Software
    By ryanh114 in forum Okuma
    Last Post: 05-29-2011, 04:57 PM
  4. Need Help!- Okuma Cadet Graphing
    By Kart 34 in forum Okuma
    Last Post: 01-30-2008, 10:05 AM
  5. 1999 Okuma cadet mate
    By NCcustom in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 03-22-2007, 07:43 PM
