Hi Normalus,
There are some quite cheap (£60) 500mW solid state lasers available on eBay, because you only need to move in 2 axis ( z not really required ) and you are only moving the laser head ( no cutting forces ) it should be quite easy to build a reasonably cheap machine, how much are the cheap Chinese laser machines after adding in the import duty and frieght charges?
LinkBack URL
About LinkBacks
