Results 1 to 6 of 6
Thread: Long Range Communication (LRC) card Multicam
    Nov 2010
    australia
    Hi guys,
    just wondering if I could pick your brains for some expert advice regarding my new router.
    Its a Multicam 11-s, Australian made model . All good and bought quite cheap at auction, minus an LRC card and any software..
    Machine uses a 4 pin plug ,connecting to the serial port on the LRC Card to a windows 95/98 desktop, yet to purchase interface software. Multicam offer Toolpath for $150
    So I called Multicam Australia who have kindly advised "they manufacture their own LRC cards for each machine to suit each specific application"..
    I am unsure what is considered reasonable as Im new with CNC but Ive just received a quote for nearly $1700 for the LRC card alone.
    My questions are -
    1. Would any LRC card be suitable
    2. Options to source used parts?
    3. Comments on quote of $1700??!
    4. Any alternate options??
    I am unsure what hardware is installed in my machine. If i recall correctly small stickers with xyzmotion or something like that??
    Any advice or help would be greatly appreciated.
    Nov 2010
    England
    LRC assistance
    Hi
    I use a Multi-cam 5000 series router in the UK, I have a very good independant machine engineer who used to work for Multi-cam uk. As luck would have it I will be seeing him tomorrow ( Monday 22nd). He has sourced many parts for me alot cheaper than Multi-cam prices. I will make an enquiry on your behalf and see if he can advise you. Hope this will be of help to you.
    Jim
    Nov 2010
    australia
    Multicam CNC
    Sounds great Jim,
    I am also led to believe Multicam models manufactured in USA use parts not suitable for those made in Australia. Cant see there be too much variation but who knows?
    The LRC Card recommended by Multicam runs only on Windows 95/98, connects to the machine via the LRC cable having a 4 pin plug one end and serial port plug for PC end. Replacement cost over $1700!
    Is it safe to assume newer hardware suitable for the same application would be available in USB connection??
    Nov 2010
    England
    Hi Again
    Spoke with Paul today He is aware of the differences with US and AUS multi-cam. Your machines are based on AXYS machines. He said to give you his e mail address and he can probably awnser you questions and tips on suppliers.
    Hope thats helpful.
    Jim
    paul@totalcnc.com
    Nov 2010
    australia
    Communications card
    Thanks Jim,
    My machine does run off hardware AXYS. Well I assume it does as if I recall various stickers in the machines hardware stating the same ..
    Hopefully I'll get this baby running, let u know how I go.
    If your ever in Australia and need to rent a car? Discounted Airport car hire
    I'll email Paul asap. Very much appreciated
    Dec 2006
    Multicam Aus
    Multicam Australia is does NOT have anything to do with Multicam USA. It is two completely different companies. Multicam Aus. is AXYZ, they just got to the name Multicam in australia before Multicam did.
    1. Mid range design #1
      By CNCadmin in forum Open Source CNC Machine Designs
      Last Post: 01-23-2011, 11:03 AM
    2. 318 Z OVER TRAVEL RANGE
      By parkson in forum Haas Mills
      Last Post: 11-09-2009, 05:49 PM
    3. Need Help!- ATC-Out of range HELP
      By Hardblackxx in forum Fadal
      Last Post: 06-10-2009, 11:21 AM
    4. Mid-range first CNC
      By iXô in forum Open Source CNC Machine Designs
      Last Post: 09-18-2007, 09:42 PM
    5. Replies: 9
      Last Post: 01-11-2007, 10:27 AM
