Originally Posted by
cubbiesfan50
I'm looking to create a new product that would be made out of styrofoam or like acrylic but cheaper, hold water, and hopefully would use a vacuum molding machine. I have a few questions about this: How expensive would it be to make a vacuum molding machine?
[I suppose you could spend almost any amount of money, depending on the parts you started with, the size, and what you wanted it to do. Your skill level and shop equipment would figure into the equation as well.]
Can I vacuum mold styrofoam?
[No. Vacuum-forming (which is what I assume you're talking about) only works with thin thermoplastic sheets.]
How can I make a 3-d figure with a vacuum mold?
[Since a vacuum former only makes single-sided parts, you'd either have to make a figure in relief or piece together a figure in the round.]
How expensive is styrofoam to buy in semi-thick sheets or the pellets?
[It's not very expensive.]
How can i get it so that the water is non-toxic? (I was thinking some kind of thin coating of wax, but I have no clue what kind)
[What water? Styrofoam doesn't poison water on contact; that's why you can drink coffee out of styrofoam cups.]
Any information that you could give to me about working with styrofoam would be greatly appreciated.
