Results 1 to 4 of 4
Thread: Can't find 25mm cat 40 tool holder
    Apr 2010
    Hello,
    I am using a haas VF2 and I have a large number of 25mm tools. I bought a BT40 25mm tool holder, which works in the spindle but is not compatible with the tool changer.
    Does anyone know where to purchase a cat 40 tool holder for a 25mm tool?
    Thanks,
    - Andrew
    Feb 2006
    try www.ushoptools.com, also you may want to try collets, they work pretty well now adays.
    Apr 2010
    Thanks for the reply.
    That link seems to be expired.
    We tried running the roughing endmill with a collet, and it kept pulling out of the collet under heavy loads. We are putting a 25mm rougher 1.5 inches deep through steel full width. Part of the problem is the roughers have weldon cuts in them which hurts the collet's grip.
    - Andrew
    May 2007
  1. what is this tool holder for
    By bassmastrbw96 in forum CNC Tooling
    Last Post: 09-06-2008, 10:11 PM
  2. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 06:04 AM
  3. Need Help!- Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum General Metalwork Discussion
    Last Post: 03-10-2008, 08:36 AM
  4. Km-3P Tool holder
    By woodr004 in forum HURCO
    Last Post: 09-17-2007, 09:24 AM
  5. tool holder
    By corrie in forum DIY CNC Router Table Machines
    Last Post: 07-23-2004, 05:04 PM
