- Need help to buy desktop cnc router for metal engraving!
Hello,
I'm hoping you guys can help me out with some options as well as suggestion regarding CNC desktop router for metal engraving. I am looking to get a Chinese made 6040 desktop cnc router 3 Axis / 4 axis machine, the big problem is every one gave its own technical spec and difference between prices are much higher.
i want to use it for metal engraving, copper, silver, bronze etc
Any help would be much appreciated!
Re: Need help to buy desktop cnc router for metal engraving!
these machines comes in a variety of flavors. 400w, 800w or 2.2kw spindle. parallel port or USB motion controller.
the usb 2.2kw is the machine you want.
What sources are you looking at? Personally, I got an OMIO X6, the 2.2kw, and although I had a few hiccups getting it going, plus had to correct a part that was not quite the right dimension, since then I'm happy enough with it.
There's flex in the bed - perhaps the weakest link in these machines overall. I added an MDF table with tracks and am now upgrading that to HDPE.
- You may not post replies
- You may not edit your posts
Forum Rules
