Help. Need spindle MT3 re-grinding u.k.
Results 1 to 8 of 8
Thread: Help. Need spindle MT3 re-grinding u.k.
    Jan 2018
    United Kingdom
    Default Help. Need spindle MT3 re-grinding u.k.
    Hi people. Crashed the X2 and damaged the spindle MT3 taper. Getting 0.1mm+ run-out
    Anyone in the u.k. know who can re-grind it or whatever you do to make it perfectly round again?
    It's the older 350w model X2 part no. 79.
    I can find a R8 one but was told it won't work with the MT3 casting, can't find a MT3 version anywhere.
    Gold Member jalessi's Avatar
    Feb 2007
    Items for Sale
    Default Re: Help. Need spindle MT3 re-grinding u.k.
    Have you tried Little Machine Shop?
    See attached link:
    https://littlemachineshop.com/produc...1906&category=
    Welcome to the Zone,
    Jeff...
    Quote Originally Posted by dazp1976 View Post
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2018
    United Kingdom
    Not cheap to ship to u.k. jalessi
    If I have no luck with Cromwell tools where I got the machine from I'll have to look at my options.
    Told Cromwell "if they can't provide parts support for their machines they shouldn't be selling them!".
    Left it with them to look into for now and see what they say when they ring on Monday.
    Feb 2007
    Items for Sale
    Lightbulb Re: Help. Need spindle MT3 re-grinding u.k.
    Dazp,
    It appears as if you are crying and no one is listening.
    A priority mail international® medium flat rate box cost $66.50 to the U.K.
    A complete brand new spindle with casting from L.M.S. cost is $119.95, with shipping the total cost is only $186.45
    If you think for a moment a spindle regrind will cost less than $200.00 you may be fooling yourself however Y.M.M.V.
    Have a most awesome weekend!
    Jeff...
    Jan 2018
    United Kingdom
    O.k. So after a bit of research I found 4 different u.k. places that look like they sell the same machine under different brands.
    All the manuals and part keys are identical.
    Osaki OSA2715500K (the one I have)
    Sealey SM2502
    Clarke CMD300
    Draper OPDRA34023
    Then you have the usual Sieg X2, Grizzly G8689, Harbor freight and so forth.
    Sealey and Clarke got back to me with the spindle in stock.
    Ordered one from Sealey and some AC type bearings from ebay.
    Lets hope it all fits.
    So far though all the upgrade bits I've purchased for the X2 have been a straight fit onto the Osaki from Cromwel tools.
    Daz.
    Jan 2018
    United Kingdom
    WTH?
    Sealey sent me a R8 spindle?
    Sealey don't even issue a R8 machine.
    For Christ sake.
  7. #7
    Jan 2018
    United Kingdom
    After numerous emails to Sealey and pictures of both my original MT3 spindle and the R8 one they sent they turned round and said "you must have the Sieg X2 with R8 taper so our part is not compatible"!?
    They're the ones who sent the R8 spindle in the first place! Banging head against the wall.
    Now. After speaking to Draper tools they've 'assured me' that the spindle they have in stock for their Draper OPDRA34023 machine is definitely MT3.
    Decided to order it and should be here mid week. Here's hoping.
    Trying to decide what to do with the R8 one one from Sealey. Keep it and have the option of R8 or send it back saying 'you try and fit a MT3 in there'!.
    I have bought a 35x62x14 bottom bearing for the R8 and as I'm using the belt drive conversion it will plop straight in without the gears.
    It's a bit stupid all this. Both taper variants carry the same part number.
    Three things spring to mind:
    1: The u.s. use imperial (R8)
    2: The u.k. uses metric (MT3)
    3: The people in the Chinese factory are thick!!!
    Rotatech Limited rang me yesterday about my inquiry on grinding mine. Haven't rang them back yet. Turns out they're only up the road.
  8. #8
    Community Moderator wendtmk's Avatar
    Dec 2005
    2: The u.k. uses metric (MT3).
    A Morse Taper is not metric. It was invented by Stephen Morse in 1860 in New Bedford Massachusetts. The USA at that time was pretty much solely Imperial measurement.
