Need advice to buy compressor for Laser cutter
Results 1 to 3 of 3
Thread: Need advice to buy compressor for Laser cutter
    Jul 2017
    Lightbulb Need advice to buy compressor for Laser cutter
    Hi
    I am buying Mitsubishi CNC 3015 LXP Laser cutter, 5 x 10 twin pallet, 3000 W, can you suggest what compressor requirements need to be?
    Feb 2009
    Default Re: Need advice to buy compressor for Laser cutter
    Looks like an older fixed optic? Our old Amada used 125psi at 8 cfm on air, but 90% of our cutting was done with nitrogen with a dewer at 175psi.
    Sent from my SM-T813 using Tapatalk
    Feb 2018
    Good day,
    We use Kaeser Compressors on all of our laser systems. Having run every compressor out there I can tell you that the Kaeser's are the most reliable on the market. They also have incredible Air to Hp ratios.... and they are super quiet. If you have any detailed questions please feel free to email me. There are few other things you need to take into consideration such as filtration, tank sizing, pipe etc.
    Cheers,
    Tom
