The company I have cutting the hardware now uses some sort of stick on gray film To negate the reflective surface of the aluminum. It is beautiful work.
Looking for a laser cutter that can handle up to 1/8" aluminum! would like a minimum bed of 48" x 12". I design Giant scale model RC aircrft and need to cut plywood and balsa also!!!
- laser cutter - Referral for a 80W Laser Cutter/Engraver Machine 700*500
- Need Help!- My chinese laser cutter won't work at all, software doesn't see the cutter
- No luck finding good set of plans for DIY CNC plasma cutter
- 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
Charles G Loud III ETCS [E-8] Ret USCG
http://www.bylouddesign.com
