- Experts recomnedations? CNC Gantry For cutting magnet sheet or fabric
Asking for some advice....
I am looking for a CNC gantry cutter to cut magnetic sheet with.
Size needed is 24" wide by 48" long (flexible on length and width)
It might be nice to have a vacuum bed or steel so the magnetic material can stick to it.
I won't need to use a router or plasma cutter and the material is fairly thin at under 60mil.
Anyone have any good recommendations for a machine I might consider for this?
I've done some snooping on the web and there are a million choices.
I'd rather not have to build one and prefer servo if possible.
Thanks for any help!
- You may not post replies
- You may not edit your posts
Forum Rules
