- 3040Z-DQ or OMIOCNC X3-300
Hi there,
I think i have found an new hobby, i can programming in php, js, sql, c and as last i have found Arduino.
What u can make with Arduino, unbelievable?! I have do a few small projects, make a gps tracker, automatic chicken house opener and more stuff like that. Now i want to but an CNC router to mill PCB plates and some aluminum parts. So i don't wanna have trapezoidal screw, the holes must be center in the lines.
What is better? An 3040Z-DQ machine from Ebay of a OMIOCNC X3-300?
I have also saw the Stepcraft 420, but someone told me that is not a very good choice, with the copper wheels on the aluminum rails.
I can spent a $ 1.500,- or 2.000,- but if i don't use the large of to large machine, than is it a waste of money.
I search for a nice and small machine in that format like the types above. I was thinking, when i not use the machine very much and it has a water-cooled spindle, is that ok? because the water/machine coolant/white water is standing there and waiting for to get died. Maybe is air cooled better for me.
Here some specs of both machines. Can some give me some good advice?
Ebay 3040
Sliding unit: Chromeplate shaft
230W DC spindle ER11
X Y Z Axis 1204 Ballscrew design
Communication Interface: Parallel
Price: ~ US $ 960,-
Mach3 License: ???
X3-300
Rail type: Chromeplate shaft+Linear Bearings
300W DC spindle ER11
Ball screw, Diameter 12mm,screw thread pitch 4mm
Communication Interface: USB2.0
Price: US $ 999,-
Mach3 License: $ 115,-
X4-800L
Or must i buy expensiver X4-800L, because that one has
Powerful Brushless frequency spindle, 800W
Rail type: HG15+HG20 Linear Guide Rails
But is the rail type so much better?
Price: US $ 1,625,-
- You may not post replies
- You may not edit your posts
Forum Rules
