- Considering a Chinese imported laser machine with weird plug socket - HELP
Re: Considering a Chinese imported laser machine with weird plug socket - HELP
If it's the power socket on the left most your talking about, that's a bog standard IEC style socket, is that what you meant? Or the big white British style Type G one?
I'd open the back up and just look where the sockets are wired to. This link might help in the meantime:
Plug & socket types - World Standards
cheers, Ian
Yes, the machine has been modified and the white socket is a standard British, 13 amp, 3 pin socket (twin and ground). However, I would guess that socket has been added for external equipment to be powered up at the same time as the laser (possibly the water or air pumps) and the standard IEC to the right of it would be to power the laser itself.
- You may not post replies
- You may not edit your posts
Forum Rules
