- looking to buy CNC Step High Z S720T router - thoughts?
Hi All
I'm thinking about buying a small CNC portal milling machine to cut plastics, aluminum front panels and PCBs. I am going to use the machine primarily for cutting plastics (delrin, POM, PC, etc).
I need to cut about 200 housings every couple of months, each housing is made up of a bottom and top part that fit together. Dimensions are 76x76x45mm. The inside of the two parts is cut out until I'm left with about 4mm wall thickness.
I want to be able to run the machine without staying near it all the time, and I want it to be able to keep running for several hours without problems.
I am interested in the CNC Step High-Z S720 machine and my plan is to cut about 28 parts out of a piece of delrin with dimensions 700x400x45mm. I could also use a piece of MDF and pocket out holes and keep individual pieces in their location so I can easily flip them to machine them on both sides. I'm not 100% sure yet about the best way to fix my work pieces and machine them on both sides without too much hassle.
I have some questions about the machine:
1) do I need a tool length sensor?
2) do I need a tool changer? the spindle that is included is a kress 1050W. I was advised that getting a tool changer will require a lower power spindle compared to the kress and that it's not necessary for my work. I won't need a lot of tools but do expect to need about 3 to process the pieces, one for roughing, one for smaller work and one for finishing.. and maybe one to cut a chamfer.
3) should I get an undercarriage and housing for the machine? I could also put it on a desk, but maybe it's better to get the undercarriage along with the machine. I am planning on getting a vacuum cleaner adapter so I can suck away the material but I was advised on also getting the housing to keep material inside the machine (machine will be in lab / office environment). I don't want to spend time doing DIY tinkering for an undercarriage or housing and want a machine ready to go.
4) should I get the T version of the machine?
5) should I get some kind of industrial vacuum cleaner to attach to the vacuum cleaner option on the spindle? some people told me running a vacuum cleaner all day will wear it out quickly and that they are not made for that and that I would need a more professional exhaust solution. The pieces of delrin will be machined out deeply so I expect a lot of trash.
6) what software should I use ? the machine comes with pcnc and construcam, I've only used deskproto briefly myself and usbcnc.
7) should I get a vacuum table? or is this something more for material that is really thin?
8) is the kress spindle of 1050W enough or should I use a different one for this type of work?
9) is air cooling OK for cutting delrin?
Any comments are welcome, especially from people who have a CNC step machine. Thanks for your help!
B
Re: looking to buy CNC Step High Z S720T router - thoughts?
I too am trying to buy a High-Z S720 from CNC Step instead of a Chinese machine (COST)
1) I feel the tool length sensor is a must
2) Tool changer - NO, I'm skipping it to keep cost down
3) I'm preparing for a desktop only. Talked to many people and that seems more than adequate.
4) Skipping the Turbo version, it would be nice to have but still skipping it
5) Using a Home Depot Shop-Vac. Again, too many people are using it and it is working fine.
6) Still undecided on the software...gonna try the PCNC & ConstructionCAM first
7) Going with mechanical hold downs & double side tape, Have 2 friends operating industrial CNC's with vacuum tables & both HAVE to use double sided tape!
8) I was talked into the Sunher instead of the Kress...wood & aluminum are my main substrate
9) Everything I've read says air cooling will work just fine HOWEVER if your planning on running yours for long periods of time I would think about water cooling
I've tried to share with you MY thoughts and I would enjoy hearing yours.
I hope to "pull the trigger" and get mine ordered next week.
- You may not post replies
- You may not edit your posts
Forum Rules
