Multi-Drill?
Can anyone tell me the english name for the machine listed at Automat boremaskine med 3 borehoveder og langbord
I'm Danish and would like to buy a similar machine just a little newer. I've tried "automated drilling machine" and related searches with no luck.
To me it seems the drill head can travel the working lenght which is described as 4000 mm (the total machine is 6000 mm long).
What I am looking for is a machine where we can put at least 2200 mm square tubing on the table and the drill head travels and drilsl 4 holes using a digital input.
Any idea for the english name for such a machine ?
All the best
Claus, Denmark
Multi-Drill?
Hi Al,
yes the drill head is a Suhner multi-drill but I am interested in the Whole setup. With at long table and motorized drill head
What it sounds like you're looking for is simply a gantry-style CNC drilling machine, with an 8ft or 3m long table.
I'm not sure there's a specific name for what you want, because of the length you're looking at suggests a specialty machine, especially if you need multiple drilling heads.
Thanks fizzizzist. That led me to "traveling coloumn drilling machine" which seems to be what I am looking for. Thanks:-)
Clause
from what you are describing:
double column (bridge) mill ( since i have not seen a cnc single column)
https://www.google.co.th/url?sa=i&rc...03409615986195
X 2200mm x Y???? x Z ?????
that is a big money machine for drilling box tube.
i would suggest 3 axix tubing plasma/laser machine, link below is a laser, but there are other companies that have simpler machines
https://www.google.co.th/url?sa=i&rc...03409885793211
hope that helps
