Originally Posted by
stones2
Thanks for the heads up, we are trying this mostly as a tool to etch photos,it's cheaper than a laser.
[The laser might be more expensive initially, but save money in the long run. For one thing, it doesn't require a continuous supply of expensive diamond tooling. For another, it might last longer than this machine, doing this job.]
What about a vacume system just for this process?
[Usually, this is done wet, so the vacuum won't help much. If you did it dry, your tools would have a shorter lifespan, and vacuum is not 100% effective in collecting every bit of abrasive dust. It doesn't take much to kill an expensive ballscrew or linear slide.]
Where does this machine stand as far as quality and price compared to other machines it's size?
