Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 01-15-2005, 01:09 AM
jfteague is on a distinguished road
Opening .dwg files in VM 5.0
Hi all. I'm new at VM and CAD/CAM in general. I'm currently taking a class on CAM which features VM. For the life of me I can't open any files that I've created in AutoCad (2004). I asked my professor but since we just started the class he told me we would cover this later. Can someone help me with this? I can't wait to get started. Thanks in advance.
Cheers -
JT
Old 01-15-2005, 07:35 AM
ger21's Avatar
Try saving as ACAD2000 format .dwg
Old 01-15-2005, 12:20 PM
Thanks for the response ger21. I've tried to save the file as all the file types AutoCAD will allow and none work. I can't understand why it would be that difficult to even open a file.
Old 01-15-2005, 09:57 PM
ger21's Avatar
Does it seem like it opens, but there's nothing there? Or does it give you an error message?
Old 01-16-2005, 09:59 AM
windsor is on a distinguished road
If you're trying to export curves from acad export them as .dxf , for solids export as .stl --- in VM open solids as .stl , for curves import regions .
Old 01-17-2005, 09:00 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
When saving the dxf as well make sure to save it as version 2000 or earlier. You should have no problem.
www.integratedmechanical.ca
How to view iges files Hack TurboCAD/CAM 1 05-07-2011 04:03 AM
CAD Files for Machine Design Hack DIY-CNC Router Table Machines 4 12-12-2004 03:58 PM
DXF or PLT files signIT DIY-CNC Router Table Machines 1 07-01-2004 05:57 PM
Visual Mill 5.0 ninewgt Visual Mill 0 02-06-2004 11:00 AM
.bin Files sundara General CAM Discussion 4 09-13-2003 06:33 PM
