Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 12-26-2004, 03:09 PM
whiteriver's Avatar
whiteriver is on a distinguished road
4th Axis Parallel Roughing
I have a 3d stl model I need to cut using only the 4th axis tool
paths. Due to its size I cannot use 3 axis roughing. I can create a
4th Axis Parallel Finishing toolpath but I can't set the Roughing. How
do I do that. Have 24" dia part need a .5" stepdown .2 stepover on the
rough and a .02 step over on the finish.
All the docs mention 4th Axis Parallel Roughing, but I don't see how
to make it work.
Thanks in advance.
Old 06-16-2007, 04:34 AM
sudhir is on a distinguished road
4th Axis Roughing option
I have a 3d stl model and I want to cut it with the help of 4th axis but in mastercam there is no option for 4th axis roughing and in finish cut there is no option to change the angle of the cut.
Old 06-17-2007, 12:10 AM
turmite is on a distinguished road
Hi Donny,
If it were Madcam I could help you out next week....I think. Wait that almost sounds like Popeye's sidekick Wimpy! "If you will give me a hamburger today I will gladly pay you next Tuesday".....or something like that!
How complicated a part is it?
Mike
to make it work.
Thanks in advance.
No greater love can a man have than this, that he give his life for a friend.
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
4th Axis UKRobotics General Metal Working Machines 7 03-19-2005 10:25 AM
Can 4th axis do offaxis undercuts ? lesd Visual Mill 3 12-17-2004 07:27 AM
4th axis machining senor J. Visual Mill 0 10-22-2004 04:10 PM
Reverse thinking on a 4th axis whiteriver Visual Mill 1 03-03-2004 12:38 AM
