Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 02-10-2009, 08:59 PM
MechMach is on a distinguished road
NPT thread milling
I how do I set up NPT thread milling?
I'm new to CAM and CNC, but I followed all the tutorials, looked through all the help sections and forums for both Visual Mill and Alibre Cam and haven't been able to figure out tapered thread milling. I'm not sure where to define the taper angle.
Any help would be great!
Old 02-10-2009, 09:22 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
I'm pretty sure you won't be able to threadmill a NPT thread with a single point cutter. The inserted threadmill cutters for NPT have tapered inserts. I'm pretty sure you just use a standard thread mill operation.
Old 02-10-2009, 09:29 PM
williams480 is on a distinguished road
It's built into the solid or inserted tool.
They make reamers for the larger NPT threads when tapping, but when thread milling 8-18 TPI NPT reaming is not necessary.
Steve
Old 02-10-2009, 09:31 PM
HuFlungDung's Avatar
Moderator
Can you draw a spiralling helix in VM?
Old 02-11-2009, 09:06 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Pretty Sure not.
Could import the geometry and program in VM with it set to output moves as linear segments. This will put a LOT of lines through the control but will work fine. This is in reference to NPT milling with a single point tool.
www.integratedmechanical.ca
Old 02-11-2009, 09:07 PM
Thanks for the input! I'll buy a muli-tooth thread mill and give it a try this weekend and see how they turn out.
Old 02-13-2009, 07:31 AM
Fred the thread is on a distinguished road
NPT thread milling
I always use the Seco threadmilling wizard for npt threadmilling.
Download the software (it's free!) from:-
www.secotools.com
it will recommend tools and give part-program output and correct cutting speed / feed.
cheers
Fred the thread
Thread Milling Don Clement Tormach PCNC 23 08-01-2011 07:48 PM
Thread Milling Dadeslot G-Code Programing 10 03-29-2011 07:42 AM
thread milling fourperf Fadal 2 11-20-2007 10:32 PM
thread milling STS_Kevin Daewoo/Doosan 0 11-28-2006 07:50 PM
