Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 03-26-2008, 09:39 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Cut start position in 2d cutting?
Can the lead in location be changed when doing a 2d profile cut? I cut different shapes and would like to have a the bit start in the same location. Now it just starts were ever it feels like.
Dennis
Old 03-27-2008, 05:44 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
If visual mill is the same as RhinoCam, the start and stop of a closed curve such as a box is where the curve was last joined. For instance, I will draw something, then decide where I want the tool to radius in, cut and exit, then I put two points right next to eachother, split the curve using those two control points and re-join.
Old 03-27-2008, 02:39 PM
chmillman is on a distinguished road
In Visual Mill the cut always starts at the curve start and travels to the end. Even closed curves have a start and end. In the edit curve toolbar, you will find a button which will allow you to change the location of the curve start/end and another for the direction. --ch
Old 04-03-2008, 11:33 PM
DennisCNC's Avatar
Thank you both, now I keep things standardized.
Dennis
Tool Start position Mike.C Carken Products (Deskam, DeskCNC etc) 1 04-17-2008 10:20 AM
how to tell where the cutting bit will start? BrassBuilder Dolphin CADCAM 12 03-24-2008 01:55 PM
Single start vs double start ballscrew. darik Linear and Rotary Motion 13 03-21-2007 08:53 PM
Newbie about to start out with CNC hotwire cutting boggyplanet CNC Wire Foam Cutter Machines 1 02-28-2007 12:36 AM
multi start thread cutting on 10TF fanuc calc G-Code Programing 5 10-08-2006 04:22 PM
