Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 08-05-2004, 04:57 PM
replicapro is on a distinguished road
Does visual mill do any cutting?
or do you need to send the g-code to mach2 or something.
Old 08-05-2004, 06:07 PM
Cold Fusion is on a distinguished road
Visual Mill is a Cam program which generates the G code. You must then run the G code with a program such as Mach2 or Turbocnc for the drivers to be able to understand it.
Proud owner of a Series II Bridgeport.
Old 08-09-2004, 01:16 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
VisualMill version 5 comes packaged with XPert DNC which can DNC (obviously) or batch send code to your machine. As well I have had good batch sending text (.txt) files to my control using Hyperterminal; which comes with MS Windows (or at least version 2000 and up)
There is also a free program called NCNet Lite http://www.cadem.com/ncnet/freednc.htm , which I never bothered to try as my VM upgrade came with Xpert DNC.
So I guess the true answer to your question is No; VisualMill does not do any "actual" cutting but is shipped with software designed to interact with most Machine controls.
Looking for Visual Mill users ninewgt Visual Mill 22 02-04-2011 04:29 PM
ONE CNC or Visual Mill ??? ninewgt OneCNC 2 07-06-2005 10:56 PM
Foam Cutting Mill (2nd Generation) FrankG DIY-CNC Router Table Machines 2 11-27-2004 08:32 PM
Visual Mill 5 - Requirements ??? samualt Visual Mill 8 07-12-2004 07:34 PM
Visual Mill 5.0 ninewgt Visual Mill 0 02-06-2004 11:00 AM
