| Visual Mill Discuss Visual Mill software here. |
I noticed that the G-Code posted by VisualMill 5 is in metric even though I have units set to inch. Is there something I am missing here ? Maybe another setup for post options ? Thanks Last edited by ringram2077; 06-13-2007 at 07:53 PM. |
| I figured out that VM has a post code generator and with that you can look at the post type you are using (in my case Mach3). I saw that the units setting was for metric rather than inch. I change it to inch and hit save, Now when I do a post it comes out in inches rather than metric. |
| Hi. First post here. I just solved this, I hope, this way: - From the top menu, go to Post Process / Post Process Generator - Select your post processor from the list. - Select "Edit" (Mach3 in my case) - In the "General" tab, under "Units" make sure "Inch" is selected. - Here's the tricky one, under the "Start/End" tab, look at "Program Start Up Code". This will be the code "block" at the beginning of your G-code. There probably is a "G21" entry. That tells your controller to use the metric system. Sneaky, huh? Chage the "G21" to "G20" - Save the whole thing, or, if so inclined, Save As.. with a name like "whatever INCHES.whatever" - Use this new post processor next time. Hopefully that does the trick. |
| Sprutcam post processor for metric units | sotos | Syil Products | 6 | 06-07-2007 05:15 PM |
| Solidworks and Visualmill | debutpic | Visual Mill | 4 | 06-24-2005 04:03 AM |
| Basic vs. Visualmill 5 | ddgman2001 | Visual Mill | 6 | 11-23-2004 10:26 AM |
| VisualMill for sale | robert_colin | Product Announcements & Manufacturer News | 1 | 06-15-2003 09:43 PM |
