Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 06-12-2007, 06:57 AM
fullfrs is on a distinguished road
Visualmill Postprocessor config
Hi!
I have an old Terco 4500 cnc and i wounder if its possible to config a new postprocessor in visualmill, for example X50.00mm Y100.20mm Z2.05mm the format must lock like this X05000Y10020Z00205 in other words it must always be 5 digits whith no decimal/ Regards Åke
Old 06-12-2007, 01:08 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
you should be able to set those parameters in the variables tab of the PP.
I suggest you contact support@mecsoft.com.
They will help you sort out a customized post.
www.integratedmechanical.ca
How is VisualMill Basic bgolash Visual Mill 6 01-02-2006 07:02 PM
Fadal and VisualMill DareBee Fadal 2 02-04-2005 11:05 AM
Basic vs. Visualmill 5 ddgman2001 Visual Mill 6 11-23-2004 10:26 AM
When the next visualmill coming out? sendkeys Visual Mill 0 10-03-2004 04:05 AM
