Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 03-15-2004, 03:41 AM
georgebarr is on a distinguished road
nesting
Can VisualMill (4 & 5) do nesting where several parts can be cut from material without wasting material space?
If not, can someone suggest the best nesting program?
Old 03-15-2004, 01:45 PM
richardl is on a distinguished road
You can import multiple parts into Visual Mill and create machine ops to mill them all from the same stock. You can use the layers to help manage this (in VM5 at least). But I think it would be easier to merge and position multiple parts using dedicated CAD software. I find the CAD capabilities of VisualMill to be awkward compared to most dedicated CAD programs.
- Richard Lawler
Old 03-15-2004, 02:19 PM
buscht's Avatar
buscht is on a distinguished road
I don't know anything about Visual Mill, but there are various levels of nesting programs available. The simplest is a rectangular nester. The programs takes the largest rectangle that your part will fit in and tries to nest that. If you have odd shape parts that isn't too good, but works well for cabinetry panels and such.
A true shape nesting program is more versatile, but more expensive.
From my experience, you can next manually better than any CAM solution. That is if you have static nests. Meaning that you just want the best nest for a set quantity and variety of parts. I just load the parts in my CAD and move them around until I like the fit.
If your parts are always different and every day the quantities change, then an automated nesting program is applicable.
http://www.mtc-limited.com/turbonest.html
http://www.merrymech.com/nestmast.htm
Old 03-15-2004, 05:38 PM
CrazyRonny's Avatar
CrazyRonny is on a distinguished road
We work with MTC Pronest at my job, it's a very good program but expensive. And we have to re-nest manually to save more material but the Pro-Nest give us a good start to work with and save us a lot of time. But to justify this kind of program you must cut a lot. We have a 10' x 40' plasma and oxyfuel cutting table and it cut on two shift.
Ron
Old 03-15-2004, 05:48 PM
Rekd's Avatar
Rekd is on a distinguished road
Hrmph, I was way off.
I was thinking NESTING was what happened to men when they got into cold water.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 03-15-2004, 09:59 PM
Thanks for the links to nesting programs. Also, what is "profiling"? I have heard of the term "profile nesting" and just plain "profiling"? Can someone clear these terms up for me?
Thanks,
Lady needs Hardware/Software Advice :) virtualoha General CAM Discussion 9 09-02-2008 09:46 PM
nesting coolman PTC Pro/Manufacture 1 04-16-2005 05:37 AM
Nesting alnicov SheetCam 4 04-01-2005 09:41 AM
3d Nesting broncosis General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2005 09:38 PM
OneCNC XR Series Profile CAD/CAM Released OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:32 PM
