Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 03-02-2004, 09:27 PM
whiteriver's Avatar
whiteriver is on a distinguished road
Reverse thinking on a 4th axis
Question about VM5 and a 4th axis. I want to put a 4th axis rotary on my router but the gantry height is only 7". Can I rotate my router 90 deg and use the Y axis as the Z and use my A axis for the rotary.
Am I seeing this correct? In a normal setup If the part is rotating then the Y axis would stay put the Z would move up and down and the X would go back and forth. Would the Y need to move or would the fact that it rotates alow the bit to get to all parts.
Donny
Old 03-03-2004, 12:38 AM
Hobbiest is on a distinguished road
I don't see why not. Horizontal milling machines are oriented in this way. Wiring may have to be reversed in actual use though (unless your software can do it) to switch the X and Z, as the X will now be the axis moving the cutter to the work.
Stop talking about it and do it already!!!!!
4th Axis Parallel Roughing whiteriver Visual Mill 2 06-17-2007 12:10 AM
4020 4th axis problems little bubba Fadal 3 06-13-2005 10:08 PM
4th axis tutorial? Monte BobCad-Cam 17 05-19-2005 10:07 PM
4th Axis UKRobotics General Metal Working Machines 7 03-19-2005 10:25 AM
Can 4th axis do offaxis undercuts ? lesd Visual Mill 3 12-17-2004 07:27 AM
