Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 01-02-2006, 11:58 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
Breakchip drill then Endmill?
Need some help making a breackchip drill opperation then using endmill from same location to machine a oval in 2.5D. I was only able to make the drill MOps in the middle of the oval then machining from there. I need it to make the hole right on the edge of the oval and then machining from there.
Any tips welcome!!
Dennis
Old 01-03-2006, 09:39 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
You will need to create a point at an offset distance equal to the radius of your drill. This point will have to be created at each oval, then select these points as the machining region in your drilling MOP.
Also; it may be easiest to create the points by using "2 point circle" creation and then use the centerpoint, this will give you the same results without needing a calculator.
www.integratedmechanical.ca
Old 01-04-2006, 09:10 PM
DennisCNC's Avatar
Thank you very much!! It works!
Dennis
