| Visual Mill Discuss Visual Mill software here. |
i am trying to cut letter out of fome with visual mill an i cant get it can anyone help me i want to cut out the shapes with 2 pass cus the bit cant cut that think i try to use profiling is that the right thing to use ?? Please Help THanks |
| Which version of Visual Mill are you useing? Back when I had version 3 it crashed alot on 2d machining. Put your file up here and I can try it out and give you a step by step on how to do it. Donny www.whiterivermfg.com |
| Yes. To cut a shape out you'd use 2d profiling. Be sure to select your regeions before using profile, or it won't do anything. You can tell it how many passes to do (depth) and weather to cut on the left or right side of your shape. Regards Terry. |
| Hmmmm. I'm not sure why that would be. Visualmill will make the gcode to the exact shape of what you've drawn. So, unless you drew it all "jagedey" I can only assume it's your router setup/mechanics. Any chance you could post a picture of your cut out item? |
| I looked at the first (VMP) file that you posted. In the Geometry list, I expanded the curves menu, and they are all polylines, so they will be jagged. Can you save the file with arcs instead of just polylines? That would fix it. |
#10
| That depends on what else you have the file saved as, other than the dxf you posted here. I've never used Coral draw and don't know what it's native editable fromat is. e.g. PhotoShop's native format is .psd If you only have it saved as the dxf, then I'd say you need to redo it and save it with arcs. I'll upload a similar dxf here in ~10 mins. You can load that into Vismill and see that the geometry contains arcs. Yours does not. So you need to either, resave the original file as a .dxf with arcs, or redraw the text and then save as .dxf with arcs. |
#11
| Check this dxf out in visualmill. If you expand the "curves" item, under "geometry" you'll see that it's made of arcs and polylines. This should give a smoother output. BTW. The simulation of the cutting is always rougher than it actually comes out of the machine. Unless of course your machines max resolution is really low, like 1mm. |
#12
| You can also set the facetting preferences and the machine accuracy outputs under preferences. But always try to work with arcs instead of polylines.
