Results 1 to 4 of 4
Thread: C AXIS machining?
    Jul 2009
    C AXIS machining?
    What I'm trying to do is machine a part that is "too big" for my machine i have the x movement needed but not y. I also have a rotary table at my disposal so the idea is put the rotary table as a C axis on the table bolt the part and have the table rotate as the x axis moves in and out to profile the part thus eliminating the y axis all together. the problem is i cant make visual mill understand. in the setup tab i changed the 4th axis to other and made z axis the rotary table and the green axis arrow shows up as expected. then i use the 4th axis profiling tool to select what i want to profile and the program completes (no errors) but the actual path is really wrong just way out in space. not to mention if i preview the path it shows the tool perpendicular to the axis of rotation this is not what i want but i dont see an obvious way to fix it. if somebody has done this before please help. even if you have not done this but have a good theory let me know ill try any suggestions at this point.
    Jul 2009
    sigh i guess not a lot of people read this forum or maybe im confusing (it makes sense in my head) surely somebody else has run into this problem i would think its a simple thing to fix if you have done it once but you have to do it once so help a guy out here ill take theories
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Yes, your post is confusing and yes I have likely done something similar.
    Try to simplify your questions and post it on the MecSoft forums.
    www.integratedmechanical.ca
    Registered Perfect Circle's Avatar
    Jul 2010
    Try changing it to a B axis....B rotates around Z that might be confusing the software..
    Is this a HMC or VMC ? I've done something close to this....
    Let me know how it turns out..
    Good Luck~!
  1. 5-axis vs 3-axis machining rigidity
    By Gabe Newell in forum General Metalwork Discussion
    Last Post: 03-15-2011, 11:54 AM
  2. Need Help!- 4th axis machining
    By ant17 in forum Wood Lathes / Mills
    Last Post: 01-16-2011, 01:37 AM
  3. Problem- 4th axis machining
    By jayroach in forum Mastercam
    Last Post: 11-04-2010, 10:03 PM
  4. 4-axis Machining
    By davebGTI in forum Surfcam
    Last Post: 02-19-2007, 10:20 AM
  5. 5-Axis Machining
    By 5AxisMachining in forum General Metal Working Machines
    Last Post: 03-21-2005, 10:03 AM
