you will need to extend the surface by half the cutter to trick-it into doing that or you will need to do the cut with a ballmill.
Hello,
My name is Ruben and I hope you can help.
I use the program VisualMill. But do not get the piece is how I want.
I give you an example. I have a plane at an angle.
I generate a "Parallel Finishing." Apparently the tour of the mill looks OK, but how wide the picture you can see that the mill does not reach the final. The mill is removed when it reaches half its diameter. So this creates is a plane at the end of tilt.
Side view.
Top View. Here you can see where the mill is removed
Anyone know what parameter I can modify the program to finish doing the roughing mill with the tilt?
Thanks.
www.integratedmechanical.ca
HI,
I have a CNC mill SPEP-FOUR basic 540 3axis.
I buy the Xpert program for windows 7 that can make 3D projects and VM 6 have a post-processor for my chance.
Why going expressions HOLDER LENGTH AND HOLDER DIAMETER IN VISUALMILL TOOL? Maybe going to SHANK DIAMETER? Or router collet?
Thank you
I do not understand?
It is proper for you to start a new thread for your questions. Not to HiJack somebody else's.
