Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 05-15-2005, 01:07 PM
an0n is on a distinguished road
Unhappy machining trouble
Hello, everyone, I am trying to machine a pocket which is a round hole in the middle in my part, the trouble is that the size comes out 2mm smaller then drawn, unless I draw the hole oversized in my cad program.
Does anyone have any idea why this is happening, or have been through anything similiar?
/Anders
Old 05-15-2005, 01:45 PM
Al_The_Man's Avatar
Tool offset correct?
Maybe if you post the program with the tool dia you are using it might help.
Old 05-15-2005, 02:03 PM
the tool offset should be correct, it's just a matter of setting up the correct tool size in the create/select tool dialog isnt it?
Old 05-15-2005, 07:00 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Any time I got a problem like this I start beaking it into smaller pieces.
I'd put a felt tip pen in the spindle and a piece of paper for my part. Then run a manually G code program to draw a circle: (NOTE: your version control probably doesn't Gcode exactly like my control)
G00 X0 Y0
Z -1.0
G01 X1 F10
G02 X1 Y0 I0 J0
G00 Z0
X0 Y0
Then I'd set up T1 for a 1/2 inch cutter and insert the command T1 G41 after the Z -1 line. See if it offsets as you expect. If so, the problem is in the cam package.
Karl
Old 05-16-2005, 07:41 AM
I'll try it after 16:00 today, Thanks for the help
Machining rubber HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 10 05-01-2011 04:59 PM
High Performance Machining or HSM Scott_bob Polls 56 04-27-2006 03:34 PM
Machining 2219-t4 aluminum scottwally General Metalwork Discussion 2 06-18-2005 11:53 PM
Reintegrating machining in our company beast General Metalwork Discussion 18 03-24-2005 08:51 AM
aluminium and steel machining Hobbiest General Metal Working Machines 3 02-08-2004 10:59 PM
