Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Visual Mill
Visual Mill Discuss Visual Mill software here.
Old 05-05-2005, 09:20 AM
emergent is on a distinguished road
distorted hole
How do I cut a .57 dia. x .95 depth hole with a .5 flat mill at an existing 25/64 hole? everything I've tried has not worked. There are two of these holes in my work piece and they come out with approx. a .83 dia. and the mill exits the first hole 1/2 way out at a 45 deg. angle. I'm new at VM5 and am using the downloaded study manual that comes with the program (I think).
Old 05-09-2005, 09:41 AM
cbass is on a distinguished road
Hey rickster, I mean emergent,
You describe the mill exiting the hole at 45 degrees. It sounds like you are having issues with your exiting strategy (the program thinks it has safely cleared your piece when it makes the 45 degree move). Have you tried playing around with your cut transfer? Set it to "clearance plane". Another thing that always got me into trouble was that I used the bottom of the piece as the zero for my Z. Its a lot simpler to use the top of the piece as your zero Z. Doing this will allow you to use the hole machining features more easily. What kind of machining feature are you currently using for these holes (i.e. pocketing, profiling etc...)?
Carlo
Old 05-09-2005, 10:54 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
If you are doing like was suggested to you on the MecSoft forum - a possible issue I can see is with the point creation part way into your part (ie at the bottom of an existing Counterbore). VM MAY (?) see this point as being clear of your part (depending on how your clearance planes are set(and also hole creation MOPs can be finicky as to what is actually the top of your part)). I generally like to draw my hole points on the top surface of my part and then calculate the hole/pocket depths from there.
I would like it if hole creation MOPs had a "pick" box for selecting top Z level.
www.integratedmechanical.ca
Counter sink hole TigerPilot General CAM Discussion 18 03-23-2005 08:37 PM
G12/G13 hole milling JFettig Mach Software (ArtSoft software) 14 03-10-2005 09:23 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 10:16 AM
How to Ream an odd(?) sized hole MikeLMR General Metalwork Discussion 6 08-30-2004 09:09 PM
Thread milling cutterdia / hole ratio HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 3 12-31-2003 09:44 PM
