You have 2 choices here...
1) In VM5, you will need to select the offending profiles (those that don't want to cut inside) and reverse the direction of the curve - it's in the edit curve tab, reverse curves.
If you have a decent CAD program, it may allow you to "uniformize" the cutout curve directions before exporting - they all need to be clockwise or counterclockwise depending on how you machine.
or,
2) upgrade to VM6 and inside the machining operation, select "inside/outside for closed regions" and check inside - no need to modify the profiles.
--ch
Thanks Much Appriecated, Not going to upgrade just yet.
Regards
