Results 1 to 5 of 5
Thread: Problem with fillet finishing in RhinoCam2
    Registered CNC Viking's Avatar
    May 2008
    Sweden
    Hi folks,
    I have trouble selecting a machining method (strategy) to finish cut a
    fillet on this training part.
    The model's fillet is R4 mm and my tool is a 7,42mm (R3.71 mm) Ball end mill and when I try Pencil Tracing, Valley Remachining, Curve Machining, Between 2 Curves Machining bla, bla, bla....it just returns a message: "Null reference error" or "Error creating toolpath" etc..
    What is wrong here? Can anyone put me in the right direction, please?
    rgh
    rgh is offline
    Apr 2008
    Mecsoft Forum
    Have you put this into the mecsoft RhinoCam Forum? The folks there are very responsive and have helped me with some of these types of problems. Typically when I run into these types of issues, it is a problem with the geometry being too tight for the tool I am using.
    May 2008
    Sweden
    rgh,
    Thanks for the tip! I actually planned to do that too, and just did.
    "Typically when I run into these types of issues, it is a problem with the geometry being too tight for the tool I am using."
    Can you elaborate this a bit, given my example.
    rgh
    rgh is offline
    Apr 2008
    Geometry
    I get these types of errors when the tool I am using is too large for the area I am trying to cut, or I have left a parameter off the tool edit that is required. An example would be trying to v-carve with a .02 bit when the largest channel is .019, or having an invalid parameter for the tool itself. (I have seen this when I don't put an angle on a v-carve rough). Though these are 2 1/2D operations, I would think it would be the same for 3D.
    May 2008
    Sweden
    rgh,
    No, I don't think it is geometry in my case. The model's R is larger than the tool's R.
    I got some assistance from Mecsoft yesterday and I suspect that I stated or chose wrong machining features (regions).
    With Valley Remachining none is needed and with Horisontal Finishing one outside of the tool path works while my earlier chosen inside of the toolpath did not seem to work.
    1. WOW, I got my RhinoCAM2.0 PRO software package today
      By CNC Viking in forum Visual Mill
      Last Post: 06-18-2009, 06:25 PM
    2. Need Help!- 3D Fillet problem
      By Powder_Keg in forum FeatureCAM CAD/CAM
      Last Post: 01-02-2009, 07:45 AM
    3. Need Help!- G70 finishing cycle problem Haas SL20
      By HAASboi in forum Haas Lathes
      Last Post: 10-14-2008, 03:51 AM
    4. Problem with variable radius fillet
      By gibsonc in forum Solidworks
      Last Post: 05-15-2006, 12:13 PM
    5. Brass CDA360 Material Hole Finishing Problem
      By TCLB in forum General Metalwork Discussion
      Last Post: 12-19-2005, 08:26 PM
