Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Visual Basic
Visual Basic Discuss Visual Basic programing.
Old 03-04-2005, 07:23 PM
ger21's Avatar
If...Then in For...Next
Can anyone tell me if there is a way to do this. I'm trying to skip over duplicate entries in an array. I'm using VBA
For x = 1 to 50 (not really using 50)
If coord(x) = coord(x-1) then next x
(do stuff here)
Next x
I get an error "Next without For" in the if...then statement. Is this not legal?
Instead I'm doing this:
If coord(x) = coord(x-1) then goto Skip
(do stuff here)
Skip:
Next x
Old 03-04-2005, 08:40 PM
Gold Member
Ken_Shea is on a distinguished road
You can do it this way, I have never timed them but understand while/wend and do/loop are more effiecient then for /next. I also do not have a legitamate data array to test.
Do While X < 50 And Coord(X) = Coord(X - 1)
' Do STuff here
X = X + 1
Loop
Stop
Old 03-04-2005, 09:04 PM
sendkeys is on a distinguished road
think this would also help :P
For x = 1 to 50
blah=blah
next x
else
msgbox "next ended"
end if
or if you want to keep going to 50. then
For x = 1 to 50
msgbox "does equal"
else
msgbox "does not equal"
end if
next x
Old 03-04-2005, 10:43 PM
ger21's Avatar
Ken, I want it to skip the "do stuff here" part if the two values are the same.This is for my AutoCAD G-code export macro. I'm trying to skip duplicate points in a polyline. The array is the polylines point list. There is a lot of code to figure out the correct g-code before I get to the Next x. I want to just increment x and skip all the code. Your example doesn't do that.
Sendkeys, I get an error message when the Next x is in the if..then statement.
Old 03-05-2005, 12:40 AM
Gold Member
OK,
Do While X < 50
If Coord(X) And Coord(X - 1) Then
' Do STuff here
End If
X = X + 1
Loop
Old 03-05-2005, 12:49 AM
Gold Member
SendKeys,
It looks like Gerry whimped out on us
Old 03-05-2005, 02:09 AM
For x = 1 to 50
'do stuff
'do stuff
end if
next x
works same way as kens but ken is right do while is little faster then "if next" so i would do it that way
remember you can also use
if not Coord(X) And Coord(X - 1) Then
too (i think hehe) vba isnt my strong point normal vb6 is.
Old 03-05-2005, 07:35 AM
ger21's Avatar
Originally Posted by Ken_Shea
SendKeys,
Hey, I had to get up at 5:00, and it was almost midnight.
I still don't think your code will work. See below.
Do While X < 50
' Do Stuff here (I want to skip this part if the two above are equal)
End If
X = X + 1
Loop
I could just use if..then..else, but I think I would have to redo a bunch of code that always takes me an hour to figure out what it's doing.
What I'm going to do instead is just iterate through the array, and eliminate duplicates and make a new array, then use the new array. This makes some other things easier anyway. Thanks for the help, guys.
Old 03-05-2005, 09:49 AM
Gold Member
OK, one more shot
Dim coord(50) As Single
Dim NewCoord(50) As Single
coord(1) = 1.234
coord(2) = 4.675
coord(3) = 3.777
coord(4) = 3.777
coord(5) = 11.024
coord(6) = 10.625
coord(7) = 3.98
coord(8) = 5.55
coord(9) = 5.55
coord(10) = 7.825
x = 1
Do While x < 11
If coord(x) = coord(x - 1) Then GoTo Skip
d = d + 1
NewCoord(d) = coord(x)
Debug.Print d; NewCoord(d)
Skip:
x = x + 1
Loop
Stop
Result
1) 1.234
2) 4.675
3) 3.777
4) 11.024
5) 10.625
6) 3.98
7) 5.55
8) 7.825
Old 03-17-2005, 01:29 AM
drolley is on a distinguished road
Gerry,
Just looking at the first message in the thread...
The problem is the multiple termination points (next x) for the loop. The language sees the first one and terminates the loop scope. The second "next x" is not tied to an open "for" statement and the translator declares an error.
As you found, your flow using the goto behaves the way you want because there is only one "next x".
However, looking at the message a little closer, you could restate the problem slightly.
Your current approach is to skip the work if the adjacent coordinates are the same. Another way to look at it is: You want to do the work if the adjacent coordinates are different.
So this should do what you want:
If coord(x) <> coord(x-1) then
(do stuff here)
end if
Next x
Dave
Old 03-17-2005, 06:59 AM
ger21's Avatar
As usual, the answer was so simple I couldn't see it. Thanks Dave. But I'm going to end up going the other route, creating new arrays. I need to do that to consolidate a bunch of different subs.
Old 03-17-2005, 11:50 AM
*Registered User*
TCARPENTER is on a distinguished road
Hi Gerry,
A little help for you - attached is a VB module you can import into your VBA routine to make your array handling life a little easier!
HTH
Todd
