Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: dxf to gcode
  1. #13
    Nov 2009
    This is what I've been looking for! I'm very new to cnc so forgive my simple questions. I use Autosketch to make dxf (there are a few different versions of dxf in Autosketch for some reason) and want to generate tool paths.
    It would be very helpful to me, and to others, if you could make a quick video for youtube that shows you setting up the files, running it, looking at the generated files, and then feeding it into a g-code simulator program to make the cuts.
    Very nice work!
    cnc1000
  2. #14
    Jun 2010
    Greece
    I have a file with extension MPG (ready to be loaded on a CNC plasma cutting machine) and I need to converted to a DXF file
    I would really appreciate if anyone can help me, by advising any free converter
    3
    4
    5
    +0+1196
    6
    30
    7
    +200-200+0-200-
    +0-546
    +250-250+250+0+
    +1100+0
    +250+250+0+250+
    -250+250-250+0+
    -950+0
    +0+230
    -70+70
    -235+0
    48
    -91+0
    -160+160
    8
    38
    -44+736
    30
    7
    +200-200+0-200-
    +0-396
    +1050+0
    +250+250+0+250+
    -250+250-250+0+
    -300+0
    -170-100
    -475+0
    48
    -101+0
    -160+160
    8
    38
    63
  3. #15
    May 2007
    Italy
    Converter...
    I dont' think there is a MPG to DXF converter. The Format, seems to be proprietary although, being an ascii file, shouldn't be too difficult to write a converter. Which brand your plasma cutter is ? May be that the company that sells it could have a converter.
    Sandro
  4. #16
    Jun 2010
    Greece
    Thanks Sandro for your reply.
    I don't know the manufacturer of the plasma cutting machine.
    Can you help me on where to find the meaning of the codes used by MPG format?
    Thank you in advance.
  • #17
    May 2007
    Italy
    If you don't have documentation of the machine it will be very hard to desume the file format. I'm surprised that you don't know the builder.. There is no builder logo or machine model name on the machine frame ?? The .MPG extension is meaningless if there is not any other reference. If you have A LOT OF TIME to spend.. try this :
    Write a program that cut for example a squared plate of known size (let'ìs say 100 x 100 mm) and examine the output code. You should desume some info like torch on and torch off command.. positioning commands and so on..
    Then pass to more complex geometries like arcs or circles..
    This could work, but it absolutely will take a lot of time and I don't know if it'worth the effort. Keep the forum updated on your researches..
    Sandro
  • #18
    Registered truonggiangcnc's Avatar
    Sep 2011
    Vietnam
    Quote Originally Posted by Megalos View Post
    I made a small application to convert dxf to gcode and i like to ask if here is the right place to submit it and get some feedback from the users.
    Thank you.
    Hi Megalos, I'm very interested in your project, and now I'm doing similar work, so maybe I really need your help. can you reupload your application, old links died all, thank you!
    Anyway, how can I contact you to discuss?
  • #19
    Registered Megalos's Avatar
    May 2008
    cyprus
    old links are dead and i'm very sorry about that., I will try to upload the files again later today.
  • #20
    May 2008
    cyprus
    new working links
    just put some files here Index of /CNCproject
    thank you
  • Page 2 of 2 FirstFirst 12
    1. Help with gcode
      By sunlight in forum Mach Mill
      Last Post: 11-12-2007, 07:49 PM
    2. Gcode
      By frankg521 in forum General CAM Discussion
      Last Post: 08-01-2007, 01:02 PM
    3. Replies: 0
      Last Post: 03-10-2005, 01:46 PM
    4. Gcode help
      By ynneb in forum G-Code Programing
      Last Post: 01-30-2005, 12:13 AM
    5. gcode to gcode converter
      By july_favre in forum General CAM Discussion
      Last Post: 05-24-2004, 07:51 PM
